I've built the following 40khz ultrasonic receiver as part of a project to measure the speed of sound in solids (wood etc.) The corresponding transmitter works well and the receiver is also partly working. There is a problem with the comparator part of the circuit (ic 5). I Measure 0.3 V with a multimeter on pin 3 of ic5 when the receiver isn't receiving any signal. And the potential divider on pin 2 is set at 0.41 V. But pin 1 is outputting 5.7 V, which should however be at 0 V when pin 3 is lower than pin 2?
Strangely, when I hold the multimeter on pin 3 and ground, the circuit works as expected and measuring with a second multimeter on pin1 I see 2mV. I would greatly appreciate any help to get this working.
Many thanks
Albert
Many thanks
Albert
