jasonallenh
I've got a headphone amp with an EI transformer that has some insane magnetostriction. The transformer has no markings to indicate any useful information. I've tried tightening it down, but it's still almost beginning to travel across my workbench. The unit works fine otherwise, but I'd prefer to drop a toroidal in it's place. I don't care if some hum gets into the audio line or anything like that- I'd rather my actual mix space be quiet and my musicians listen to the hum
That being said, I disconnected the transformer. It's a CT secondary and each leg is at ~23V from the center tap, and 46.7ish volts away from the center tap. The amp has a 1amp fuse, so I'm assuming I don't need more than that from the secondary. Based on this and my own questionable educated guessing, I am led to believe this transformer should drop right in it's place-
http://www.mouser.com/ProductDetail/Hammond/1182K12/?qs=%2fha2pyFaduhLGMeoOSzIMdptrs0JOMq7ZnppQ7FwMbU%3d
How did I do? If I'm way off, could you please describe your process for determining a drop-in replacement? If it were any other component, I'd have no issues
