Hi all,
Noob here with a number of successful "paint by numbers" builds under my belt. Still don't really know anything about anything and would be most appreciative of all guidance.
I've got a external PSU for a channel strip that keeps popping fuses. These are both off-the-shelf units that have never been opened/tampered with.
The PSU worked well for years and just went down mid-session(obviously). Fuses are popping with the psu both connected and disconnected from the preamp.
The Fuse holder is in the IEC socket, one side goes to a spst power switch, and feeds the primaries of the transformer. This all checks out fine.
Now, the transformer is popping fuses both with the secondaries connected to the psu board or with the secondaries disconnected from everything(and each other of course!!). The voltage(before the fuse pops) across the secondaries is pretty to spec (24.5v on a 22v secondary) both connected and disconnected to the psu board.
The fuse normally pops after about 3-4 seconds. After this, the transfomer is warm to touch.
I'm getting continuity both across the primaries and the secondaries of the transformer, no continuity between primaries and secondaries though
Am I correct in surmising that my transformer has gone bad? What should my next step be? Should I swap out the transformer? Is it likely that something else caused this or does it sound like the transformer just went(maybe a power surge from the mains or something?) Am I in over my head? Should I call a tech? Shipping it to my gear pimp would likely end up costing lots and taking ages.
Thanks for reading this. Any suggestions or guidance massively appreciated.
Rob
Rob
