PT ratings
syn
Hi
  I have a couple of questions regarding PT secondary ratings. Is there any reason not to use a 40V transformer for a +48V power? After the bridge it is going to be ~56VDC so plenty of a margin left for  regulator to regulate. Same question for heater  PT ratings, 7VAC should be enough (~10VDC after the bridge)
and again ~3V margin left for the regulator to do its job?
Thank you
Only if your rectifier has zero Volt forward drop.
But if you have a 7VAC winding, why not power the heaters directly from it? If you're concerned about the 10% overvoltage just insert a resistor.
JD 'KISS' B.
EDIT: Typo
Thank you jdbakker. It is a PCB job so I want DC to power the heaters.
