Pultec EQ make-up gain
kevinc
Reaction score
0
Apex, NC
Anybody know how much make-up gain is necessary to bring the 1KHz response back to unity gain with the most drastic cut scenario? I am asking this question in the context of the passive circuitry without the output buffer/amplifier.
Reaction score
101
Winnipeg Mb Canada
I thought it was about the 20db range , of course leave yourself a trimmer
to adjust for unity [ 15-25 ? ]
keefaz
Reaction score
13
Paris (France)
Just curious, why do you want unity gain 'with the most drastic cut scenario'
If you get unity gain with frequency cut, you won't get unity gain in bypass mode for example
Reaction score
101
Winnipeg Mb Canada
there is a constant lose from the filter network , for which the makeup
gain compensates and like most of that style you are always going through the electronics whether bypassed or not
radiance
Reaction score
11
the Netherlands
I believe every section can cut up to 15dB so I guess the make up gain should be between 35dB.
Maybe 40dB to be on the save side...So you're going to have a gain knob on the unit as well?
shabtek
Reaction score
79
midwest usa
do you want the level to jump 15-20 dB when switched to bypass??
instead add a level control?
Reaction score
101
Winnipeg Mb Canada
Every section does not cut the whole range 15 db , just their range
there is the insertion loss that because it is passive , does not boost
but cuts less at thoses ranges . [ but not the inductor mid boost ? ]
I still think it is simply between the 15-20 db mark and can be set & left
if it were a true bypass it would be different , but that is what the makeup
gain does , unless you just want extra gain
