Pultec PEQ1A: audible clicks
white noise
Active member
The Netherlands
When I switch between the low frequencies on my Pultec PEQ1A EQ, with the low boost full or almost full, I hear audible clicking sounds when I turn the switch, but when I reduce the amount of low boost, the clicking doesn't seem to be that present (or is not there at all). On the high frequencies I don't notice this problem so much. Is this normal because there is so much low boost added to the sound, or should I never hear any clicking at all, no matter what switch I turn? Has it to do with non-shorting or shorting factor of the switch? Thanks in advance!
All the best, David.
[quote author="CJ"]or 1 meg resistor from wiper to hot...[/quote]
gah.. I'm sure this is so simple but I can't seem to envision it. :? So how would I connect a 1M resistor on for instance a 12 pole bmm switch, like on an EQ? The pole is the wiper...? and hot would be each contact? Is there a schematic I could look at somewhere? I'd really love to be able to use these nice ceramic wafer switches but they are all bmm.
thanks,
Kiira
i think this might work:
