my experience re: some of the pots mentioned:
alphas feel great (if you like the damped feeling) but WILL wear out eventually. i have had to replace a bunch of alpha pots in gear i've bought, and in most cases i've just put in new alphas, knowing that they'll be just fine for at least another 5 years. certainly for inexpensive proto work, having a few of every value of alpha pot that's readily available is a great idea.
at work we use a lot of the clarostat 308/388 series pots (sold by state electronics) which, though they are sealed, can be opened and are modular enough that they can be reassembled into many different configurations. andrew has more money sunk into clarostats that most diy'ers would be comfortable with, but with what is available we can now make just about anything.
the pots i've used from omeg were conductive plastic and not sealed. the construction looks similar to the alphas, and they feel okay. the only turnoff (for me) is that they are AFAIK only available with plastic shafts, which are, though sturdy, more breakable than metal shafts. certainly for the price, if you need a custom part, they'd be the first place i'd go.
ed
