David Kulka said:
Similarly, if you had a AC line variac you could could power up the the unit and gradually increase voltage while monitoring current.
In my humble opinion, anyone messing with electronics on any level including newbie, needs four things to successfully get started:
1) Common sense
2) A digital multi-meter / VOM / VTVM / wet finger and experienced tongue
3) Soldering iron / Weller gun / butane torch / thermite
4***) A Variac / Powerstat / serious lighting dimmer that doesn't freak out with inductive/reactive loads.
*** a poor mains variac substitute can be as simple as a light bulb in series with the DUT (device under test).
Take a cheap-ass short extension cord, cut into the sheath in the middle to expose the wires within, cut the black (brown) wire, and connect both ends to a light bulb socket. Have a selection of various wattage incandescent bulbs, no CFs, no LEDs, just good old fashioned edison-invented tungsten-filimented GE soft-white bulbs. Start with the 15 watt one, work your way up, paying attention to the bulb brightness as in indication of load current. It does take a bit to get a feel for what brightness level is good or bad, depending on the expected draw of the DUT.
An enhancement on the above: A toggle switch from after the light bulb socket to neutral. With the switch closed, the light is fully on. THe DUT is connected and on, open the bulb switch, and a nice, gentle ramp up of current in the DUT. This avoids the DUT dealing with the surge of powering up a cold light bulb, where the current can be 10 times the hot current.
For what it is worth,
Gene
