Spiritworks
I built an 87-style mic from a complete kit from Dachman audio. As expected, it was a fun build with a decent result, but not a "wow" moment. A bit bright, which I attributed to the capsule. So I bought a capsule from Beezneez to replace the kit one, just to see if there was an improvement. I highly expected there would be, but alas, things didn't change all that much - if at all.
However, with the Beezneez capsule installed, I noticed that the rear plate, in figure 8 mode, seemed much better than the front - more full range, less fizzy....
I would expect capsules to be balanced on both sides. If I flipped the capsule around and re-soldered it, I would say there was an improvement when in cardiod.
Any thoughts about why this is, what I should look for? The only thing that comes to my mind is that there is a bias adjustment in the mic circuit. Does that have to be tweaked for the new capsule? I have built almost a dozen mics from various sources, all of which we use all the time in the studio with good result, so this one is a puzzler.
