Question about John Roberts Parametric EQ
nachvai_89
New member
Hi everyone, first post here.
I want to make John Roberts Parametric EQ my first DIY proyect.
(This one
http://www.mnats.net/files/parametric_article_john_roberts.pdf)
What I wanted to know is how to add balanced inputs and outputs to the circuits.
Thanks in advance
This is what I have in mind.
I added a circuit schematic, the SVF is not complete.
I added the balanced inputs and outputs from the Douglas Self book.
Do you think it will work?
Warm Regards
    56.8 KB
Thanks in advance
Do you want to use transformers or IC for de-balancing and balancing?
Electronically balanced outputs is easy with one SSL9K balancing board
