marktokach
I have tried all search functions and scrapbook plus which is helpful, but still have problems finding things. I need a little help with wiring the mains and iec fused connector on the the G7 psu. The switch i have is a carling SPST fender amp switch. it has only 2 connections. i have an iec connector with fuse. Will this work? I have it hooked up and its blowing fuses.I think i have it hooked up wrong. I have read it's better to have a Dual ON-OFF Double Pole, Single Throw = DPST. Does it really matter? It seems easier to hook up with DPST because it has at least 4 connections. I read it's safer too because it disconnects both neutral and hot at once. I have to order this one and want to get this working already. Can I safely use spst and does it go on the hot side or neutral or doesn't it matter? TIA
