figuringstuffout
- Joined
- Dec 10, 2011
- Messages
- 45
Hi, I'm new here and hope i can get a little help with an issue I am having.
So i have recently built my first tube preamp, complete with jensen input and output trafos and while the thing sounds freaking amazing, I am having a slight issue with connectivity.
You see, when I connect it to any mixer (just plug the xlr into the input for a channel), firestudio, or any converter with a built in preamp, my tube preamp has tons of volume (more than my UA 610 has), and sounds amazing. However, when I connect it to my Apogee Rosetta 800, my tube preamp sounds thin and has very little gain before it starts to distort like crazy. The 610 has no problems here interestingly enough so i don;t think it is a problem with the rosetta......
My first thought was that is is an impedance mismatch but I don't see how that is possible....if anything it should be a mismatch going into a mixer since my Jensen Trafo runs an output of 600 ohms.
JT-10K61-1M
Note - i have a cathode follower 12au7 with a 25uf cap right before the output trafo
Potential Solution?
just thought of something, let me know if I am simply fooling myself.
The Jensen Trafo is 10k:600 rating in ohms. Thus, when taking the signal from before the plate resistor (somewhere in the 30K+ ohm rating) I would be properly seeing the 10k ohms in the Jensen and the output would be properly in the 600 ohm rating. However, since I am using a cathode follower right before the trafo, then I'm actually driving the Jensen at way under 10k ohms and thus throwing off the 600 ohm output, probably making it closer to the 150 ohm ish rating of a mic input. Thus when I run the preamp into a mixer preamp, or whatever, it sounds perfect with tons of gain because it is matching impedance, however the Rosetta gets pissy with it because it wants to see 600 ohms and is instead seeing way less.
Thanks for any help that might be offered.....
JT-10K61-1M
Potential Solution?
