Pip said:I would take Oliver at his word personally. He does this stuff a lot.
The C800G mic is a very unique and special animal. That Peltier junction is critical to the sound of the mic as is the oil bath that surrounds the tube. I see much of a path to try and recreate this machine in a DIY package. Also it is still under manufacture keep that in mind.
It is also not what I would call a go to mic it has its uses but they are very specific voice timbres I have discovered. I had a chance to buy one years ago and kicked myself for a long while untill I realized that I probably wouldn't use it that much.
Maybe a C37a?
JessJackson said:Pip said:I would take Oliver at his word personally. He does this stuff a lot.
Maybe a C37a?
I should have given a little more background before writing my specific post.
I own two c800-g's and have some spare populated replacement boards that I ordered from sony a while ago, all i need to add is housing, tube capsule (k67) and transformer. I will use original neumann capsule and add filter 100pf cap. if top end is still not smooth i will try replacing the electrolytic caps one by one.
I've never been happy with the top end of my sony's and instead of modding and ruining resale value of mic, I will build a hacked one, trying different types of components until top end is smooth.
Your wrong about Peltier section though, it doesn't contribute to the sound of the mic, it is purely to keep tube slightly cooler, there is no oil bath, its a small amount of silicone paste between the Peltier and the tube to help the heat transference.. its a complete gimmick and definitely not necessary in the build.
cheers J
Just to add comment about this. No, there is no oil inside, just the silicone paste and thin copper foil around tube to ensure better cooling. Btw, I don't see any problem with recreating this in the DiY. I'm not sure about transformer winding scheme/inductance, but I'm sure that one of the vintage Neumann BV tx will drop in. At last, measuring primary inductance of the original transformer can be a good start.That Peltier junction is critical to the sound of the mic as is the oil bath that surrounds the tube
Russian 6AU6 is 6Ж4П. If I remember correctly original tube was marked as "Sony 6AU6" but dimensionally it's same as 6Ж4П. So I replaced the dead tube with Russian. In the PSU are American 6AU6's and yes, they can work inside mic but sounds bit different.gyraf said:The C800G tube is probably not an ordinary 6AU6 - if you take a close look, it's longer than a real 6AU6. My best guess is that it is the Russian near-equivalent (forgot the number, is it 6J4P?) - and using those, you get fewer rejects when checking for microphonability.
Btw, the rejects can be used in the PSU (and if you're in a pinch, you can use a tube from the PSU in the mic)
Jakob E.
See also:
http://www.groupdiy.com/index.php?topic=23666.0
http://www.groupdiy.com/index.php?topic=49521.0
Melodeath00 said:Very interesting about the tube. I'd love to eventually see a GroupDiY C800G build.
Gus said:Melodeath00 said:Very interesting about the tube. I'd love to eventually see a GroupDiY C800G build.
Why?
Also look in the microphone meta
Why clone something do something different.
Why?
Melodeath00 said:Jess, what transformer did you end up going with?
