I've whipped together a through-hole and slightly altered version of the sE 2200A circuitry (with a DC-DC converter on another board, and a pattern selection switch added), and i'll have a batch made (10 of each board), most likely at Itead.
If, by some miracle, others are interested as well, i can easily add more batches to the order - the boards would come out around 1$ each, plus shipping.
Now, my (minor) concern is, would that red trace (top layer) coming from the center pad on the left edge of the board, affect the high-impedance area of the circuit in any way?
The 1G resistor will be between the octogonal pad on the top left (below the mounting hole/pad) and the grey "target" (a hole for the teflon stand-off).
