Ian MacGregor
Hi, I've been searching for some info on this, but I'm having a hard time finding anything.
If I have a Transformer that is suited to supply a +/-24V Bipolar supply (~45VAC CT), can I also use this same transformer to power a +48V rail? The two bridge rectifiers would be in parallel. The 48V bridge would have the negative DC side grounded to the same ground that the transformer center tap is grounded to. For some reason, it seems like one of the diodes in the 48V bridge would be shorting out one of the transformer windings.
Any ideas?
Any ideas?
