Jamin Lambiris
Member
- Joined
- Nov 4, 2014
- Messages
- 15
Hello Everyone is been a while.
I have successfully modded 11 mixer Cards over 3 Workhorses. Not including the master sections.
Here are the Problems
The Relays are not turning on.
So Far I card changed all the Electrolytic Capacitors to Nichicon UHE's
Removed all the Zener Diodes tested them and put the back.
Removed all the NPN Transistors tested those and put them back.
Replaced burnt Resistors with new ones.
Replace Switching Diodes with new ones
Removed Relays from another card and put them in the one, The other card works flawlessly.
I have tested the voltage at all 9 Test Points same result in all 9 locations 15.75V.
However R1 and and D1 which are in series I measure a less 14.80V These two are connected to the positive rail.
R3 and D5 are the same but connected to the negative rail and measure 14.75V
The other 11 working modules measure over 15V in both positions.
Does this have anything to with why the relay wont open and what could be causing this voltage drop.
