hoodun
Active member
- Joined
- Sep 17, 2014
- Messages
- 41
I just acquired a Ran HC-6 Headphone Amp and it did not come with the power supply, It turns out the ps is an odd rj45 wall wart supply that is 18v and 6.75 amps. It is discontinued.
I found a diagram that says it is two 9v outputs that go into the unit. I'm guessing it goes in there in series. Could I connect a 9v single wall wart that is 7 amps into the same inputs? It must go in there in series.
