Re: the Lorlin Switches..
dufo
Melbourne, Australia
I wonder...
is it possible, if you say have a 3 or 4 pole switch and need a single pole one, to simply cut off the extra pins? would this work? I have alot of these switches but they are all 4 pole. For the G9, I was thinking of just cutting of whatever pins required to get my 3 and 1 pole switches required. Thanks.
??? Why cut them off? Just ignore the ones you don't need.
unless I have this completely wrong...
Because for eg., a 4 pole one has 4 pins, but the PCB for a single pole switch only has a hole for the one pin. So to fit, I need to cut the extras off.....no?
Oh.
Yeah, whack off the offending pins.
I sorta did that in my first SSL... I accidentally got 3 pole 4 pos lorlins rather than 4 pole 3 pos, but I noticed only one pole was actually USED, so I just bent the other two under so that the switch fit the PCB.
i got some 2-12 position lorlins from mouser today and i can't figure out how to change the stops. need them to be 3 position. i see stop-holes on the panel side of the switch but no stop-pin. is this another 'mouser classic' where you have to order the $.02 dicky part (needed to make it fully functional) AFTER the main order arrives?
did you take the mounting nut off?
There's a washer with a downturned flange under the mounting nut - that's the stop. :)
