Studio Mollan
- Joined
- Oct 26, 2011
- Messages
- 323
I started drawing on this a while back. It's a 500 series module that converts +4 balanced signals to unbalanced via transformer, then high impedance unbalanced to +4 balanced again. Much like the Radial EXTC500. I already own one of those and it's great! Makes me able to use my Space Echo as a +4 insert with a minimum of noise and great sound.
I plan to use it as either a loop for old gear that actually needs a 1Mohm input inpedance, (like the '63 fender reverb) and also as a normal +4 to -10 converter. The way I see it it should work for both? or? Any opinions greatly appreciated. EVERYTHING inserted here will be of some sort of LOFI nature so it does not have to have 20-20k bandwidth and other features considered hifi.
I have a spare 500-chassie that I'm planning to fill up with these. It's not really worth a lot of money anyways and if I succeed with this design it will become a cost effective alternative to the Radial. If I get it working I will offer PCBs to anyone interested.
One addition to the design is that it also incorporates a high,- and low-pass filter, I went with a design I've already used in diy, the Harrison Ford filter.
I would appreciate any feedback on the design. I'm not too comfortable drawing up my own designs. Iv'e looked at other designs, borrowed and modified them to suit (or hopefully suit that is).
Signal Flow:
Input is a NE5532. One half as a balanced receiver and the other as a variable send gain. Then a transformer, via a polarity switch to a front panel mounted 1/4" jack.
Signal returns via another front panel mounted 1/4" jack that feeds a OPA604 high impedance buffer. From the buffer into the filter and filter switch.
The filter Switch feeds the output amp either signal straight from the buffer or from the filter output. The signal is always present in the filter, the switch just switches the filter output to the output amp. The output amp is another NE5532 wired as a balanced line driver with variable gain.
I'm a bit ashamed of the output section.. It's pretty much the output section of the JLM audio Dingo PUP....
I might just replace the output amp with a THAT1646. A bit more expensive but worth if if not intruding on others designs. If I use the THAT1646 I will ned to reconfigure the OPA604 with variable gain. Using I as a standard non-inverting op amp with gain instead of a buffer. Probably fine.
The frontpanel will have: 4 pots; HighPass, LowPass, Send and Return. 2 Switches; Polarity and Filter. 2 LEDS for Polarity and filter. And finally 2 1/4" jacks for interfacing the pedal/tapedelay/etc.
I'm not sure about the transformer. Radial uses it in the EXTC500 and that sounds pretty sweet. The zobel network is from the Radial box. That I might have to recalculate at a later stage, when I have a working prototype. I'm not sure I really need it, or if it's going to work. Opinions here if you have any.
So, if you see any errors or such please comment. I think I've taken it as far as I can.
Signal Flow:
