dbonin
Any anecdotal responses to this, using the DRIP u47 with and without the 200 ohm output attenuator? 600 ohm T-PAD with no mods?
Cheers all,
Don
Cheers all,
Don
dbonin said:So this is what I'm thinking, I have some 200 ohm stepped attenuators that I can use on the front end.
But to make it just a bit more versatile I was thinking of wiring in a bypass switch that will remove the attenuator completely.
Best of both worlds, I'm thinking.
mixguy said:I've finished a Redd 47 but it has a high frequency whine on the output. It does not vary in level with the gain knob but varies with the boost switch. Any ideas on what could be causing this?
Register today and take advantage of membership benefits.
