Redd47 CMMI-7C wiring confusion?
orangechili
Daytona Beach, Florida
I have a Redd 47 pre i'm in the middle of building and a little hung up on the CMMI-7C input transformer wiring. According the cinemag pdf it says that the 20pf/100k junction of the zobel network goes to ground but according to my layout i'm using it says the 30k/100k junction goes to ground on the other side. I'm wondering which is correct or if I'm missing something here? I'll attach both documents. Any help here greatly appreciated
    115.7 KB
Do you know basic electricity? Lamp and switch. Series circuit. Does not matter if you wire it as switch then lamp or lamp then switch. Either way works the same. (Yes, in permanent wiring there is a convention to reduce confusion and shock, but the electrons don't care.)
The 30K+20pFd are in series. Make that connection, then treat the assembly as one part. It can go in the circuit either way, cap-up or cap-down, it is the *same*.
Ok, please forgive me if it seems like a dumb question but have seen a few people asking through various forums on how to wire this transformer and there were no particular answers. So wire color doesn't matter on each of the secondaries of this particular transformer. Just wanted to make sure before i wire it up and didn't want to change where ground terminated on the amplifier layout and mess something up.
