drmachismo
New member
Hey All -
Wondering what everyone uses as their input signal when building gear that takes a microphone input. I looked at the spec sheet for an SM57 and found its sensitivity rating of -56 dBV/Pa. If I convert this to Vrms and use 60 dB SPL as a "quiet" level and 130 dB SPL as a "loud" level it would follow that the output for these two levels is:
-56 dBV/Pa = .001585 Vrms/Pa
...and since 1 Pa = 94 dB SPL
SM57 output in Vrms @ 94 dB SPL = .001585 Vrms
So...
SM57 output in Vrms @ 60 dB SPL = 60/94 * .001585 = 1 mVrms
and
SM57 output in Vrms @ 130 dB SPL = 130/94*.001585 = 2.2mVrms
Seems logical, but the SM57 spec also states that the sensitivity rating is for open circuit at 1 KHz. An input transformer would load the microphone and I would expect the voltage seen at the input of the mic transformer to be lower.
What are you all using as an input signal to simulate a mic input when tuning gain staging?
So...
and
