Scodiddly
I've been fooling around with the TI Launchpad w/ MSP430 chips for a bit now, and I'm starting to use it for things. Nothing fancy, could probably be done with simple logic or a 555 chip perhaps. Mostly LED dimming and control.
Anyways, these MSP430 chips barely use any power at all, something like 60uA at the most and usually much less. I made a little Altoids box that does nothing but blink LED's and play annoying noises, and a pair of half-dead AA batteries ran it for almost a month. Now I'm putting together a desk lighting controller that will control and/or dim some 12v LED strip lights on different parts of the desk, and so I've got a 12vdc supply and the controller will only need in the neighborhood of 3vdc.
So I'm thinking that the usual suspects (LM317 and related) would be overkill. I only need a tiny trickle of current at the most... so maybe just a voltage divider with a big cap to act as a buffer? Or maybe a fairly high value resistor down from the 12vdc to a 3v zener for regulation and a cap to act as gas tank. Definitely don't want the 3v supply to waste more power than its customer actually uses!
