Regulator footprint?
matta
Cape Town, South Africa
Hi Guys,
I am wanting to buy some regulators for one of Fabio's PSU's.
But now the issue is I can get LM317 in both TO-220 and TO-92, which
one do I get? Or can I use either? How do you know which of those 2
packages to use?
Matt
Electrically they're the same of course (except for maybe lower power dissipation on the '92). Do you have the board with you? or a picture of it? It should be obvious which one to use by looking at the PCB footprint.
Peace,
Al.
It just occured to me that maybe you don't know what TO-92 and TO-220 look like... Is that what you're asking? If so, you can download the datasheet for the device and they usually have mechanical drawings of the available packages.
Peace,
Al.
Thanks Alk :thumb:
That cleared it up, I need TO 220, it is for a PSU and looking at what other people have stuffed them with that is what I need. Also the schemo shows pins 123 not CBE.
Here is a pic of the board:
I did try get the Datasheet off Alldatasheet.com, but my connection was VERY slow... got to love Africa.
Thanks again
Matt
[quote author="matta"]Also the schemo shows pins 123 not CBE.[/quote]
Actually, the pins on a TO-92 are also numbered "1 2 3"... The image I linked to must be for a specific transistor in a TO-92 package (C = Collector, B = Base, E = Emitter).
But don't worry about that, looking at the PCB, you definitely want a TO-220 regulator. :thumb:
Peace,
Al.
I built up one of Fabio's PSUs with a few slighly different components last night for a pair of Neve 1272s... as alk said, TO-220 is what you need. I bought a couple extra of these from Fabio. These are great little PSUs !!!
Are you using this for an API?
PS - Your THAT 2180LBs are on their way !!!
Hey Greg,
Thanks for the info. I have always used TO-220 for all the PSU's I've made in the past (which ain't many, 3 to be exact), but when confronted with the TO-92 option I paniced :oops:
I was dealing with a parts store on the phone and they asked which option and it threw me since I only knew of the TO-220 package in the LM317.
Alk, thanks for pointing for the BCE was not related to the Reg TO-92 package, I can clearly see it is a transitor (A BC184 to be exact), I was stupid enough to miss it first time around.
Back to the PSU, I am hoping it will be for a pair of Fabio's API's, I have the boards which I will slowly stuff as and when I can, get both time and money :)
I have just wrapped up my 'channel strip' with 2 Greens and a Calrec, the rack looks very Ghetto DIY, I'll post some pics in a few days but It sounds great though :thumb:
Thanks for the news on the THAT's! I have pretty much bought 80% of the parts already, and while I was ordering the regs for them from your list I ordered a few regs for the PSU as well.
Matt
If you still need the datasheet, go to http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=14&M=LM317T and click on the lower link, the one that says "LM117/LM317".
In general, a good way to find datasheeets is to go to www.digikey.com and do a search for the product. When the hit screen comes up, click on the version of the part you want, then click on the link for "Technical/Catalog Information" which is farther down on the screen, below the price info. Digi-Key doesn't carry everything by a long shot, but they have good datasheet links for the semiconductors and passive parts they do carry.
Peace,
Paul
hey Matt:
Check out this thread if you're going to be building a Bauman PSU. There are a couple simple mods that will make this PSU perform better.
http://www.groupdiy.com/index.php?topic=5282&highlight=bauman+psu
The main thing, if you look at the schematic, is the 5VDC will load down the phantom supply (and create alot of heat), so it's a good idea to take R10 from the R1/C1 junction.
TO-92 pack is good for maybe 0.3 Watts of heat.
TO-220 is good for 20 Watts (if clamped to a silver bar in a cool lake).
Regulator Watts are the Current times the Wasted-Voltage.
So if you start with 8V and regulate to 5V, and only have a 10 milliAmp load, you need (8-5)*0.010= 0.030 Watts. TO-92 is ample and smaller and cheaper. If you just have a couple chip opamps, a couple TO-92 is probably ample.
But if you start with 25V and regulate to 15V at 100mA, (25-15)*0.1= 1 Watt. A TO-92 will melt (actually these regulators just shut-down). You need the TO-220, and probably a heatsink.
A naked TO-220 "will" dissipate 1 Watt, and I've seen it done commercially, but it runs way too hot for my taste. So I'd add a couple square inches of sheet-metal. Above 3 or 4 Watts you need a Real Heat Sink, generally an aluminum extrusion (though you can get "9Watt" stamped/bent sinks that I would put 5W into).
I bet you can get these regs in SMT. With proper PCB copper-foil area, dissipation can be similar to TO-92, maybe better. But most DIYers don't do SMT.
PRR,
Concise as always! Many thanks :thumb:
Thank goodness I didn?t buy the the TO-92 and try it, though it sounds like
it will just shut down under over load as opposed to ?releasing smoke?.
It reminds me of a funny blooper with regards to ?releasing the smoke?.
I was working on a pilot light for my rack and had a neon that could be
connected to 220V AC and an standard LED for low V DC connection, they had
the same package/casing and I grabbed the wrong one and connected the
LED to 220V AC.... lets just say if you ever want to see and hear a pop and
smoke... try it... It took around 3 days to clear the smell out of my
workshop...
Greg thanks for the info on the Bauman thread, I checked it out and it made
for a good read.
Matt
> it sounds like it will just shut down under over load as opposed to ?releasing smoke?.
These regulators are pretty smoke-tight except for over-voltage and reverse-voltage. (There used to be UN-protected regulators like the LM100/105 and 723, but they went out of fashion pretty quick when protected regulators appeared.)
If you are ever in a situation where you can get "the same transistor" in TO-92 or TO-220, remember that transistors are happy to smoke. For several reasons, you never find the exact-same transistor die in -92 and -220 cases, but when you start cross-referencing to find something in-stock be sure to watch the case option.
