Bo Deadly
I accidentally made the relay flyback diode on a pcb too small. The footprint is for a signal diode. But I'm wondering if I could get away with using a signal diode in this particular case because the coil is powered through a 2n7000 mosfet which is turned off by disconnecting the gate from the control voltage which means the capacitance of the gate will need to drain through a 10K pull-down resistor (although this value could probably be increased to 100k without a problem). So this will slow down the turn-off action ever so slightly. Do you think that will reduce the back emf of the relay coil enough to get away with using a signal diode instead of a proper high voltage rectifier?
Does anyone want to take a guess as to the inductance of a TQ2-12 relay coil? If I knew the inductance of the relay coil I could test this in LTSpice.
