hello,
can i use normal relay switches that switch back on a specify position if they are powered off?
The idea is to bypass the machine if it is switched off. i would feed it the relays with 12v or 24v if the machine is on so that the relay
is switched to a fix position when it is powered on... if it is unpowered the relay should switch back and bypass the wires... so that you do not need a bypass switch anymore.
if the machine is unused you can power it off... would be great for the ssl comp i have.
another idea i had to bypass the machines after the individual "coming-from-output" that the signal does not need to go unless to the machine and back.
This should work fine like a extern bypass with switches wired to the desc (controller). Anyone who has realize a similar thing?
PS: of course not for tube stuff that could be damaged if you just need bypass for comparing the audiosignal.
what do you think about the power off bypass?
