Silvas
If i were to replace the rotary 12pos lorlin on the green pre for a pot, which values will work? lin or log? surely i have to add a series 1.5 ohm in series for the +66dB gain setting to work correctly.
OR
how to add a trim control so you have at least +/-5dB range adjustment over the output? the 6dB steps sometimes are too big for some applications, and it would be nice to have more control over this...
Yeah, a 24 pos rotary...but i´m in Colombia, i´ts impossible to find a 24pos rotary...
THANKS !!!
----EDIT-----
I´m building the Mk1, not Mk2, and putting a 10 segment bargraph meter display, Mk1 seems simpler component-wise and i like that. Also, i made files so a friend can make professional PCB´s for the green...
OR
THANKS !!!
----EDIT-----
