vinyvamos
In the past days I have been working my way through this piece of old US Navy equipment from about 1961, which is essentially five compressor modules in a rack with trafo balanced ins and outs. The frequency range is quoted at 200-5KHz on the output trafos, but both input and output iron sweep perfectly from 20-20K. This is not the first time I have tested MIL-SPEC iron to be way better than stated. The F.R. when measured was more like 140-10KHz (-3dB), so the limited range must be in the circuitry. I am now trying to increase some coupling cap values to at least lower that crap LF shelf... Anyway, back to that later...
What is very unusual about this design is that it seems to use a network of varistors for gain reduction in front of the first amp stage. Can this really be? Am I missing something essential here? They are all reading in the Mega ohms range when tested in circuit. I have read one discussion on here about the uselessness of them for this purpose...
https://groupdiy.com/index.php?topic=26880.0
The designators on the board are RV201, RV202, etc and you can see them in the attached image. The dark metallic grey discs in two sets of three on the board. I will also post an image of the entire schematic if anyone is interested. It is all PNP germanium transistors of just one type; 2N461. The main supply is a regulated -30V while there is a low current zener reg. +30V being provided to the sidechain section.
