saint gillis
I'm trying to fix the PSU of a Roland Blues Cube combo. I've retro engineered the primary side of it, there seem not to be any feedback loop in the SMPS :
On the secondary, there are some little 1.6A fuses, then diodes, inductors, and filtering capacitors.
First time I had my hand on it, one of the fuses, and one the diodes was blown on the secondary, I've changed them and I've also changed some 100µ filtering capacitors on the secondary. The mosfets also were blown.
Then I've changed U1, Q1 and Q2. The amp worked fine for about 30min, then boom again.. U1, D3, Q1, Q2, Q3 and R7 dead...
I thought it was because I've used AOTF20N60 for Q1/Q2, as the AOTF20N60s have a weak power dissipation factor... Soooo, I've replaced them with IRF740 as at the origin, replaced U1, D3, Q3 and R7, the amp worked fine... for about 30min again.... BOOOOM, U1, D3, Q1/Q2 dead...
I'd like to avoid to replace the mosfets and the driver ad libitum... anyone experienced with this kind of circuit ?
