FreqFarm
Active member
I am in the process of restoring an SH2 which is in much need of some love.
I have started with the power supply as it makes sense to get that sorted and stable first before sorting out the various other issues.
This is a 220v SH2.
Issues Solved so far:
1) PCB is a different version to any of the ones in the service manual, but not a problem to trace and confirm the connections coming back from the transformer which is where the difference is from the diagrams.
2) Main PSU caps C45, C46 and decoupling caps C51, C52 replaced (these were the original lilac coloured ones) and are working as expected.
3) Output from transformer to PCB was wired wrong, although the power supply was working as expected both prior and after correcting the mistake with the same output voltages at the 15v rails.
Current Issues:
1) Output from 1B4B41 Bridge Rectifier is +35.5v / -34.8
This is 15v higher than I was expecting and 5.5v higher than the 30v max the TA7179 is spec'ed to handle so clearly not a good thing.
Questions:
1) Are these output values within spec?
+15v rail: +14.88
-15v rail: -14.86
2) If I am getting higher than expected DC voltages from the 1B4B41 Bridge Rectifier is this due to the 022H020D transformer outputting a higher than expected AC voltage? And if so this will mean the transformer needs replacing?
Relevant Diagrams:
This is a 220v SH2.
Current Issues:
Questions:
+15v rail: +14.88
-15v rail: -14.86
Relevant Diagrams:
