sonolink
I apologize if these matters have been discussed in the forum or if this isn't the right place to post this, but I couldn't find a thread dedicated to the subject. If anyone knows where this thread is, please don't hesitate to point me to it.
1)
On premise that when you want to use a Multimeter to check i.e. voltage, you should connect the ground first and then the live lead keeping one arm behind your back, my question is: which ground? Are all grounds the same? Are "power ground" and "audio ground" the same? If I have a star ground shall I just keep the black lead plugged to it and use the red lead around?
2)
I built a cap discharge tool as recommended by Jakob on his G9 page. I have also read that it is also recommended after bleeding the caps, to leave the Multimeter on the circuit while working on it. Where shall I "leave" it? Where do I connect it?
3)
Although this is not personal safety, it does relate to components safety. Is it a good idea to fire up a circuit for the first time with empty sockets (no tubes, no opamps, etc) to avoid frying them? If so, do I have to bleed the caps before placing the tubes and opamps in their sockets? How do I know the circuit is ok to place them in their sockets?
Again, I apologize if this has been covered already or it's the wrong place to post. I am about to finish a couple of builds and I really want to be sure about some things before hitting the power buttons and diving in. ;D
Of course, I appreciate any other safety measures/advices you might think of.
Thanks in advance for your time, input and help.
Sono
1)
2)
3)
Sono
