klem
I am building a cable for FM's @Marik AL959 stereo ribbon mic. I was advised that cable lengths over 3 meters could have an impact on the sound of passive ribbons (I planned to make a 10 meter cable).
I used the handy calculator at Calculation of cable length, cable capacitance C, and cutoff frequency cable attenuation treble loss damping microphone mic cable capacity wires XLR capacity - sengpielaudio Sengpiel Berlin and looked at 2 cables (both are quad, but to be used 1:1 wire
in as it's for the stereo mic)
Plugging in the data below for either a Gotham or Canare, I get a value wayyyy above human hearing, and that value is cutoff frequency that's only 3dB of attenuation. So, what's the potential issue here? Or maybe there's something outside of this for what would impact the sound with a (properly shielded/terminated) cable run >3 meters?
https://www.gothamcable.com/en/gothamcables/starquad/11001gac4155 pF/m
https://www.canare.co.jp/en/products/cables/index.php?tid=4_001150 pF/m
AL959 Output Impedance: 250 Ohm
10 meter cable
Canare: 424413 Hz
Gotham: 1157490 Hz
10 meter cable
Canare: 424413 Hz
Gotham: 1157490 Hz
