I just noticed the Left and Right of my SB4001 is 5db out. It seems to be the unit and not the rack, as this issue only occurs once I put Comp In on. Could this still be a rack issue, even if it only occurs when the comp is on? I did buy this new 500 series rack used.
I am thinking of fixing this through the calibration process:
Unity Gain (VR1L/R) - Toggle between bypass and comp in. Adjust VR1L/R for unity gain (ie - same levels when the compressor is engaged as it is when it is in bypass)
It's been a while since I worked on this project, so I cannot recall if I need to dismantle the unit to access the Left and Right trimpots?
Has anyone ever had similar issues as this, and how did you solve it?
Could this issue be more than the trimpots adjustments, as I rarely used this unit. Could something else be causing this issue - capacitor, resistors?
Is it normal for the left and right to eventually drift and just need a trimpot adjustment?
Any tips regarding troubleshooting this issue and confirming it is just a trimpot adjustment?
Thank you.
Thank you.
