I have been testing some transformer using REW with my Scarlett 2i2 as the input. Because I am testing at line levels I use the Scarlett's TRS input with the input set to line. This should give me a 10K input. However on a balanced floating input this doe not work. The level is about 40dB below what it should be. After a lot of faffing around and head scratching I tried connecting pin3 to pin one on the XLR connected to the transformer output (I use and XLR to TRS cable to theScarlett). Bingo, up pops the level to the expected reading. So, it looks to me that the ring of the TRS is left unconnected. I can imagine it is OK if you plug in an unbalanced synth with a TS plug or even and electronically balanced source but transformer expect both hot and cold inputs even at line level.
Before I take the top off to check, has anyone else seen this issue?
