LevinGuitar
- Joined
- Jun 13, 2019
- Messages
- 493
I'm trying to understand how affect using a capacitor to feed the output PNP transistors (C9 in original Schoeps) versus not using it like Alice circuit does.
I find that this cap affects the curve response and increase THD (the 47uf seems to be a selected value for this circuit, I tried different values and this one works the best) but removing it makes the mic cleaner and way brighter at first (I'm talking about any Chinese mic that uses this circuit). Increasing the value of C2 and C3 as the Alice does from the original 0.1uf helps to bring the low end back but here there is a problem, the bigger value, better low end, and after 4.7uf is hard to find a film capacitor that would fit any mic. Maybe 10-20uf would be enough to have a similar low end to a circuit with that C9 47uf cap or not, I don't know. 3.3-4.7uf are quite ok and there are some 50v caps that are small enough to fit in many mics. Using a electrolythic, even a good one, results in a downgrade of the sound, no matter what value we use (I tried up to 100uf), so it must be a film one.
Does anyone have experimented with this?
I definately like more the sound removing that cap and increasing C2 and C3 value, but in some mics, without the respective C9 cap, there are a low noise. Where it can comes from? In the old NT2 there are no noise issues with this mod.
