Securing brittle wires on old transformers
Murdock
Germany
Hey folks,
what would be a good way to secure brittle wires that come out of the bobbin of old transformers?
I heard of super glue or paraffin / wax.
I fear some stuff would maybe kind of expand when drying and would damage the winding when it get's inside of it.
I know potting is an option but would rather use a less invasive technique.
Any tips/experience?
Thank you too.
Most importantly, cyanoacrylate reacts with certain compounds and causes burn. You can try it on for example a bit of toilet tissue and see the smoke generated. The same will happen with polyurethane content. It may not cause smoke with certain types of paper but it may generate heat which in return can be damaging to the enamel.
Also if you ever need to rework on the transformer you'll be ripping things apart.
Someone else suggestes wood glue (especially the brand Ponal).
Seems easy to apply, is transparent when dry and could be removed with moderate heat.
Any thoughts about that?
