Voyager10
After a bit of playing I've got an LTSpice simulation which (approximately) emulates the RF circuitry of the MKH 405 / 415.
The schematic is as follows:
The essential elements are based on the MKH 405 schematic from this thread: Sennheiser
The heart of the original circuit is coil L2, whose various windings are represented here by L1-L4. I've simplified the oscillator section, so the original coil L1 is not shown. The capsule is represented by C3, which varies either side of a nominal 27pF.
Running the simulation shows output voltage Vo varying as C3 changes:
Now before anyone gets carried away this is not intended to give accurate values for any of the inductors in the circuit, or the actual voltage levels, it's currently just a demo of theory behind how the FM detector works.
