5v333
I am experimenting with a regular balanced input stage which is made of an op amp and 4 resistors. Since all resistors are equal in value, i can only see what the gain margin is on my scope.
The amp is stable but i would like to know what the phase margin is as well. Is it possible to find out?
I think I have read that you can set the amp with a little higher gain than unity (10 dB-20 dB) and then play with compensation before you close the amp o unity.
