rock soderstrom
Tour de France
I am still working on my tube PT2399 delay which should be optimized to generate shorter delays. The delay should complement a tube spring reverb and should generate early reflections and short slap back echoes.
As you know, the delay time of the PT2399 is set on pin 6. The current flow is the variable to be changed, pin 6 sits constantly at half operating voltage, i.e. 2.5V.
As far as I know, a current of 2.5mA must not be exceeded, which corresponds to a minimum resistance of R=2.5V/0.0025A=1K, which corresponds to a minimum delay time of approx. 35mS. However, this varies from chip to chip, my available chips are above 40mS.
Other sources say that you should not go below 2k, because otherwise the "PT2399 will latch-up during the power-on sequence and the internal oscillator won't start."
My chips are fine with 1k, but I want even less. This analysis shows some possibilities to realize shorter times without "latch-up" , would my variant work?
What minimum delay time can I expect?
