Hi everyone - I'm new here. I have been here and found lots of great info in the past.
I have a question. I made a DB25 to DB25 cable. I had soldered 3 DB25 connectors that day and must have been tired cause when I tested the cable with a continuity meter, I found that a couple of the wire on the last DB25 connector I soldered were touching and shorting. So I fixed it. But this got me wondering...
This cable goes from the analog output of my AD/DA converter to another box (a summing box I built). If by any chance any of these wires were shorting to each other, would this just degrade the audio signal or could it actually cause damage to the converter?
Rob
Rob
