krabbencutter
I've been trying to DIY a W295b and it's confusing the heck out of me. Like some folks already mentioned in the forum, the High/Low Shelf is basically an active Baxandall EQ. I've simulated it in LTspice and put the circuit on a breadboard and everything works so far. When comparing it to the Soundtoys Sie-Q the low shelf behaves completely identical, but the high shelf is way off. My breadboarded high shelf behaves like a standard baxandall high shelf but the High Shelf in Sie-Q works much more like a 17KHz Constant-Q Bell filter.
Picture 1 shows a 6dB boost of SieQ (pink) and my breadboarded circuit (blue) from 1kHz upwards
Picture 2 shows my simulated circuit
Picture 3 shows a 12dB boost of SieQ (purple) in comparison to a 17KHz Constant Q Bell curve (pink, slightly offset)
Since Sie-Q is the only available reference, I don't know if Soundtoys decided to design the high shelf differently or if I'm missing something on the schematic?
