As I specified before posting (you quoted that part too) the 1/2/3 pins are totally random, I just took whatever connector was handy in terms of footprint in Eagle's librairy and used it to quickly submit the schematics here. In real life I'll do a clean and appropriate wiring, no worries.
Regarding the NE5532s : there are TWO ICs per channel in the schematics. In each channel, the first IC is called U1and both "halves" of this 5532 are used . Second IC is U2 and I'm only using half of it.
Anyways, in the newer and last design I removed the second IC. The 2nd half of the first IC is now driving the output transformer, as discussed here with Abbey
I'll post updated schematics if you want, as well as PCB pictures and will keep you guys updated with the build.. if you want to
