Buttercup
Ok, so I'm using a 1:1, centre tapped (+48v going into the
centre tap via a resistor ) for a simple mic input, and the output
is going unbalanced (20k secondary ) to a domestic camcorder
with a mini-jack connector.
Can I just put a VR between ground and the output or will
this cause problems?
Needs to be really simple if poss.
Thanks.
Giles
Thanks.
Giles
