Consul
I finally had an epiphany today about an instrument I've been wanting to build. Other members might remember my talking about an electro-mechanical string machine, where stretched strings are pressed against a moving rosined belt by the player pressing the keys. After thinking about a number of ways of accomplishing this and not liking any of them, I finally started to wonder if I could have the strings always pressed against the belt (and thus always excited), and then use some really simple transistor switching to turn the sound on and off via a keyboard. And then I had my epiphany.
The basic idea is to make a keyboard that has 37 audio inputs, each one being gated by the 37 keys. (I picked 37 based upon the idea that three octaves can cover a pretty usable range of notes for studio recording purposes.) So now, I can build any tone generator that creates up to 37 notes (it doesn't have to use all of them, after all) individually, and then I can play it as an instrument. 19 Walkmans playing tape loops? No problem. A big cylindrical 37-stringed hurdy-gurdy with individual pickup coils? Why not?
So now, focusing on the keyboard itself, each key will need some kind of VCA, and some kind of envelope generator. Since I'll need 37 of each, I'd like to make it as simple as possible. I also want all of the envelopes to have common controls so they'll all make the same shape, set from a single panel.
I'm thinking this might be a tall order.
I found the famous one-transistor VCA schematic (I've attached it), which should serve well enough for that part, but once I start looking into even simple A(S)R envelope generators with voltage-controlled A and R settings, and the idea of keeping it simple goes right out the window. I'm wondering if I'm missing a trick.
As for connecting to the audio source, I'm thinking a 40-pin ribbon cable, same as parallel IDE disk drives use. They're ubiquitous and cheap, and would probably do the job over short distances. 40 pins should be able to do 37 signals plus a common ground.
I still have all 88 keys off of the piano I salvaged, and will probably use those for the keys, adapting the old piano keybed as well. I just need to figure out a simple mechanical switching system for gating the A(S)R.
Wish me luck. Any ideas concerning the control of attack and release on 37 VCAs would be much appreciated. Thank you!
