ruffrecords said:WOW, you invented time travel! That downward trace goes backwards in time.
One of the kids hasn't stuck a fridge magnet on the side of the scope have they??
Most scopes use electrostatic deflection so it's not likely to be a scope fault. However, most of them use steel cases which can get magnetised.
dfuruta said:A few weeks ago, my oscilloscope started doing this. Has anyone seen this before? Is there some easy cure?
My thought is maybe something got magnetized, but I'm not at all sure that's right.
gyraf said:Try moving a magnet around the outside of the scope to see if you can compensate - that'll show if this is the problem. I had something like this on a very-old tek I had once, "cured" by rotating the mu-metal screen around the crt.
Jakob E.
