I'm having some fun and games this morning. :sad:
I'm looking at a Trace Elliot GP11 bass amp for a bass playing friend - he say it was making funny noises and not passing audio. I hooked up a junk test speaker and blew it up! (And the speaker fuse twice).
So I wired up another test speaker, this time with a chunky 33ohm resistor in series to limit current. The resistor started to smoke within seconds of turning the amp on - and red hot to the touch (ouch).
I measured the DC voltage across the output: -57V DC !
:shock:
Well that explains the symptoms, but I'm stuck looking for the cause. Has anyone had any experience trace elliott amps and seen anything like this? Anyone got a schematic?
Some more details:
1. The power supply is dual-rail ±57V.
2. I don't get continuity between the output and the -ve rail when the amp is switched off, so I don't think it's a simple short.
3. The 'bodies' of the output transistors are also at -57V.
4. The preamp section of the amp seems to work just fine.
Any ideas or suggestions would really be appreciated.
Many thanks in advance.
Stewart
:shock:
Some more details:
Stewart
