SOLD: 2x Mytek DSD 8x192 + protools hd card expansion
fonzobrown
Italy
Unfortunately my friend have to sell some of his studio equipments.
Here it is a Mytek DSD 8x192 ADDA mastering grade 8 channels AD and DA converter with outstanding word clock distribution system just powered by a protools hd expansion card ( Mytek Protools HD DIO CARD ) that let You interfacing this converter direcly to Protools HD pci/pcie cards.
8x192's features are:
- Digital format conversion between AES and any of two optional DIO Cards installed
- True precision mastering grade 1dB per step stepped attenuator
- Analog mix buss assignable to 4 pairs of stereo channels or 8 mono channels
- Additional to 8 analog outputs, 2 XLR outputs which can be assigned to any pair of channels or Mix Buss output
- Hi-current (500mA), hi-speed, low distortion transparent headphone amplifier
Internal clock jitter
<10picoseconds
Conversion
Linear 24 bit PCM
128x oversampling at 44.1/48k
64x oversampling at 88.2/96/176.4/192k
optional
64xDSD, 128xDSD
External sync
Wordclock in and out. Wordlock Out can be used as house clock: 15 LS TTL loads max.
Wordclock outputs
6 separate Wordlock Outs
to be used as house clock: 15 LS TTL loads max.
Can be terminated.
Dynamic range
ADC: 120dB (A weighted)
DAC: 123dB (A weighted)
Analog inputs
+4dBm balanced or unbalanced, 10kOhm, D25
Analog outputs
+4dBm balanced or unbalanced, D25 plus 2 XLR
Digital inputs
8 Hi-speed (25-200kHz) AES/EBU
SPDIF D25
Digital outputs
8 Hi-speed (25-200kHz) AES/EBUS
PDIF D25
The pinouts of D25 I/O
connectors are compatible with Protools HD (tm) Digisnakes (tm)
THD + Noise ADC
ADC: -106dB (<0.0004%)
DAC: -110dB (<0.0003%)
Mains
100/115V-220/240V 50/60Hz switchable
Dimensions
1 rack space wide x 1U high x 9” deep
14 pounds
Headphone output
Hi-current (500mA), hi-speed, stereo
Stepped attenuator
24 steps assignable to phones and XLR outs
Mix buss
2x4 pairs or 8 mono, true analog mix buss
there's 2 unit to sell, price is 1985 euro ( for 1 x Mytek 8x192 with Ptools Hd expansion included ) + shipment from Italy
and 3800 euro for both
You can find some production's example made using this mytek at his site: bedrecords (dot) it
for contact him directly : info (at) bedrecords (dot) it
All the best
    291.2 KB
