firerunner
Member
- Joined
- Sep 20, 2017
- Messages
- 20
Hi friends,
I have a Hafler XL600 that was purchased used and is exhibiting some strange behavior.
Initially the first issue was the fan kicks on immediately when powered on, even with no load. A few different owners have mentioned the fan should be quiet and relative to the listening volume, and this unit's fan seems to be running close to full speed, it's blowing the leaves on a plant across the room and quite loud compared to the listening volume.
I figured the idle current was possibly changed by the previous owner and triggering the fan prematurely, but upon inspection the bias pots are set at the factory (I assume) and glued in place.
When I put a meter on a rail of one of the audio boards, it starts around 350ma and creeps up over 400ma (factory spec) and continues to rise. I let it get to 450ma before powering down.
My first thought was to replace the transistors in the fan control circuit, but since these seem to be separate from the audio section, I feel there may be another issue that is causing the idle to increase.
The power transistors are mosfets, could they be exhibiting some kind of thermal runaway? The amp sounds good, no audible distortion or issues.
Attached is the schematic. Has anyone experienced an issue like this in their power amp? Any help or insight would be appreciated, thanks!
