Analog_Fan
YouTube's algo suddenly came with video from people repairing amps.
I'm trying to prevent some inrush current problem.
My first drawing was resistor, capacitors only.
The second was similar to a youtube's amp repair video, using resistor, cap, npn.
But i don't wanna use relay's and the constant current.
I tried some solution found on stack exchange, but none of them work.
I need to apply this to both rails, Falstad show my circuit worked on the negative rail, but not positive rail whilst being the same accept PNP.
although they should, i even got the same results in LTSPICE.
No rising "edge", pretty much the mosfet turns on instantly.
I wanna place this after bridge rectifier.
The added image is supposed to work solution posted on stack.
![soft start.jpeg soft start.jpeg](https://cdn.imagearchive.com/groupdiy/data/attachments/81/81766-b1a19d303374d816ffc798a6bb9a7500.jpg)
any one got a solution?
