Hello, if anyone can help diagnose a problematic c414 b-uls, would be grateful.
The mic powers on and makes some loud popping (clips), similar to when you switch polar patterns or a drop out in phantom power.
The popping starts in just about 30 seconds after starting up or changing polar pattern and goes for a minute or so, and then generally settles down and doesn't reappear. It seems to 'warm up.'
At the same time, After 30 seconds, the level of the front capsule (or 0 degree axis, anyway) drops a good 10db or so. So that registers as a drop in level in cardioid/hypercardioid, and a drop in level from the front of the mic in omni and especially fig-8.
Does this sound like a problem with the capsule itself, or a problem in how the preamp circuit is applying voltage to the capsule(s)? How to go about figuring out, without swapping out both?
Any help appreciated. I have a clip of the sound but not sure if I can post to this forum.
EDIT: I did already put in a new polar pattern switch, with no effect.
